I tried solution in a shot glass and used one of the small pens and dipped a small milled piece of hobby store brass. When I pull the piece it is covered with a green scale. It will polish off and I have an ok amount of plating. Is this solution spent? There is some sentiment in the bottom of the glass. The brass piece is 3/4"X1/4"X1/16" dunked for amount 2 minutes in room temp solution with the metal of the pen about a 1/16" in the solution. It starts off with nice fizzing but seems to weaken after a while. I have 24 of these pieces to do, should I just get the regular nickel setup and dip them all. The pieces are all cleaned, shiny and sitting in walnut shells in a tumbler and ready to go. Do i need to scrub all of these with soft scrub first!(yecch).
Thanks Greg |
the hobby store brass might of had a clear coat of some type on it??
bill
http://home.comcast.net/~jhodges87/wsb/index.html |
More than likely the brass did have a clear coat on it, as this prevents the brass from tarnishing as stated by bhhodges. You will need to use a paint stripper to remove this then clean with sof scrub or dish detergent and thoroughly rinse with distilled water before plating. I would suggest dipping more of the wand into the solution when using the immersion technique.
-- Craige Brooks Caswell Inc http://www.caswellplating.com Need Support? Visit our online support section at http://support.caswellplating.com Have A Web Site? Why not join our affiliate program and earn 15% of all sales. Join at http://www.caswellplating.com/affiliate.htm |
| Zinc Plug N Plate Dark Streaks/Coverage Capacity Questions | ms042180 | Electroplating Questions | 3 | 12-21-2006 11:48 AM |
| Plug n Plate Gold over Sterling | novenarosary | Electroplating Questions | 0 | 03-12-2004 10:00 PM |
| Plug n Plate | lphurley | Electroplating Questions | 3 | 09-23-2003 12:15 AM |
| Plug 'N' Plate | Laird | Electroplating Questions | 1 | 02-25-2003 02:16 AM |
| Plug N Plate Copy Chrome question | Great_Scott | Electroplating Questions | 5 | 03-20-2002 05:53 PM |
