NEVER add "fresh" (tap) water.. ALWAYS use Distilled Water to top-up your tank.. Assuming you are using the Caswell "buckets", it's a wise move to mark the "full level" in the outside of the bucket, using a Sharpie or Marks-A-Lot.. I read somewhere in the Caswell Plating Manual that the solution will last for "X Number" of square inches of plating, be dipped if I can find that info now.. |
If your liquid level is dropping due to evaporation, then yes, you can top it off w/more water. But if your liquid level is dropping due to "dragout" (electrolyte remaining on the parts when you remove them), that needs to be replenished w/fresh solution. Let your parts drain off well over the tank before going to rinse, and you won't lose much at all. Sean
Seans Zinc Plating page |
Thank you for your reply. I only use distilled water in my tanks. I will pay more attention when I remove the parts from the tank. I must say, this site and your knowledge on the subject has helped me through fustrating times. At this time the results are what I expected when I purchased the kit. Before that things were a bit dicey, burnt parts etc. I'm more organized now.
Peter |
| Copy Cad Help (Power Supply Problem ?) | Rab | Electroplating Questions | 13 | 03-23-2007 12:57 PM |
| Copy Cad with heaters, Temp. up past?? | MrPontiac | Electroplating Questions | 6 | 12-16-2006 10:23 AM |
| Copy Cad Stainless Steel? | rockitdoc | Electroplating Questions | 2 | 10-19-2006 04:48 PM |
| Have I ruined my Copy Chrome solution? | IanHardaker | Copy Chrome Kit Customers Only | 1 | 10-10-2006 12:07 AM |
| Cloudy Copy Cad solution ?? | Bobby-S | Electroplating Questions | 0 | 04-23-2006 02:31 PM |
