Hi everyone - I am new and not sure how best to get an answer to this - I need to gold plate small (@ 0.25 in long x 0.125 inch diam.) electrical connectors for pcb boards. The connectors are machined brass finished with Electro Brite Tin. I don't want to use a wand - it will take forever - and the plating 1 gal kit is too large. My questions are:
1. Can I scale down the 1 gal plating kit by purchasing say the 1 pt solution and SS anodes and make a practical dip-type tank? 2. What material should the cathode be made of? I could fabricate a bracket which would hold say 10 - 15 wires on which the connectors would be attached to dip into the plating solution - what material should I use for the wires? copper - aluminum or what? 3. Does anyone have experience with how the plating reacts with the heat from soldering? Thanks for any advice anyone can offer. I will check this post daily. Gary Ferguson |
i think you are wrong saying the brush plating will take to long espically if the 1 gallon set up is to big, look at the fast gold brush plating kits.
bill
http://home.comcast.net/~jhodges87/wsb/index.html |
| Plating stainless steel watchcase with white gold | fredj | Electroplating Questions | 1 | 06-03-2007 04:58 AM |
| PNPG12 24ct gold brush plating solution | jerrylim | Electroplating Questions | 1 | 05-28-2007 02:42 AM |
| gold plating services sought | brooksie1 | Services Offered/Wanted | 1 | 11-19-2006 02:13 AM |
| Gold Plating and Nickel plating | tzmandevil | Electroplating Questions | 2 | 09-16-2005 09:11 AM |
| gold plating on brass | jomida | Electroplating Questions | 5 | 02-23-2003 10:34 AM |
