Old 04-09-2007, 02:20 PM
goldmankc is on a distinguished road
Post rust coming thru plating
I recently gold plated an antique screw driver. I wire wheeled it, buffed and polished, then nickel{heavy} then gold, problem is in about a month, rust spots came back thru the plating. What did I do wrong? not sure of amps, equipment adjusts automatically, brush plater. Help.
Old 04-21-2007, 08:57 PM
ashcroft01's Avatar
ashcroft01 is on a distinguished road
Default Re: rust coming thru plating
goldmankc,
Chances are the brush plating technique did not allow for a thick enough coat to prevent further corrosion.
To help combat issues like this, especially when brush plating, it may be wise to start your bare metal with a coat of Copper first. This will aid in the prevention of moisture seeping through the Nickel and back into the steel. It also helps the Nickel adhere and creates a thicker overall plate.
Brush plating leaves an incredibly thin deposit compared to immersion plating.
The amperage requirements are self adjusting on the brush plating system.
Best of luck,
Curtis Ashcroft
M and C's Plating & Powder Services
Old 05-02-2007, 11:35 AM
thanks, I'll try that.
Plating steel and cast iron: Rust removal/pickle tokay Electroplating Questions 0 12-20-2006 07:40 PM
after nickle plating rust chipmetal Electroplating Questions 1 05-25-2006 10:55 PM
Zinc Plating an old auto radio case engineerscott Electroplating Questions 1 02-18-2006 01:08 AM
Improving Plating Performance jimcarry Electroplating Questions 0 09-28-2005 08:50 AM
plating and size power? chromo Electroplating Questions 7 01-18-2003 02:52 AM
