Old 03-09-2003, 10:32 PM
Matt Harwood
Default Question about regulating amperage
OK, let me see if I've got this straight: I want to cadmium plate a large brake backing plate 13" in diameter. Surface area is approximately 270 square inches. At 0.02 A per square inch, I need a little more than 5.3 amps to make it work. So far, so good.
Now, I have a battery charger capable of 6 or 12 volts, and up to 10 amps. From what I've read here, I need to regulate this down using light bulbs. For instance, I need to string together enough bulbs so that their combined amperage is 5.3 A, correct? So if I have 5.3 A worth of illumination, I should have 5.3 A worth of plating power, correct?
This seems counter-intuitive to me, since a bulb is nothing more than a resistor, and it seems that I am adding resistance to the circuit. It seems that I should have 10A - 5.3A = 4.7A worth of bulbs instead.
Can anybody clarify this for me? Thanks very much, it is appreciated!
Matt Harwood
Cleveland, OH
Old 03-11-2003, 02:07 PM
Matt Harwood
Nobody knows?
Matt Harwood
Harwood Performance Engineering
Cleveland, OH
Matt's 1941 Buick Century Restoration
Old 03-11-2003, 02:31 PM
aermakov@rogers.com
Hi.
I normally approach these calculations from a standpoint of power (Watts). Your charger can output 6V * 10A = 60 W of power. At 5.3A required current, your backing plate will consume 5.3A * 6V = 32W of power. To achieve proper current drop you will need to burn off the excess 28Watts in bulbs connected in series with your plating setup.
An easier solution would be to plate both parts at once, if the tank is big enough. 10A will plate these really well in about 25 minutes.
amperage question padstack Electroplating Questions 2 03-27-2005 04:06 PM
Peak voltage question mudwhump Anodizing Questions 6 01-14-2004 11:53 PM
Chrome (re)plating question - howto olaf_sc Electroplating Questions 1 07-29-2003 03:00 PM
Electroless Krome question tbloss001 Electroplating Questions 1 07-24-2003 03:13 PM
Brand Newbie Aluminum Polishing Question gdsegel Metal Polishing Questions 1 04-25-2003 09:04 AM
