Old 05-20-2007, 05:45 PM
seb21051 is on a distinguished road
Default what type of plating would you recommend?
The front brakes on my 1982 Honda Blackhawk started binding, so I took apart the calipers and found some corrosion and slight pitting on the pistons, mostly about .25 inch from the outside surface that contacts the brake pads.
The bores seem to have a yellowish plating, some of which of course wore away as I was polishing them. Now the pistons, which seem to be made of steel, would most likely rust and corrode even sooner.
The question I have is what would be the best plating to use on the pistons?
Thanks for having such an excellent forum!
PNPG12 24ct gold brush plating solution jerrylim Electroplating Questions 1 05-28-2007 02:42 AM
Plating Surface Quality for Plastics neeraj_bapat Electroplating Questions 4 01-13-2007 02:16 PM
Improving Plating Performance jimcarry Electroplating Questions 0 09-28-2005 08:50 AM
identifying a plating type unteroffizier Electroplating Questions 0 07-28-2004 10:42 AM
What type of cleaner do you use before plating? Josh I Electroplating Questions 2 11-26-2002 11:00 AM
