Old 05-23-2007, 04:15 PM
theshoer is on a distinguished road
Default nickel plating guns
First I know about metal prep. If its not prep proper its not going to plate proper. I will be plateing a reproduction 1860 colt cap & ball pistol. My Question is What do I do about the inside of the barrel and there are a couple of pins and holes they fit in that I need to worry about. I have never plated anything that tolerances are a concern. One more thing what about screw hole.
ABIG THANK YOU FOR ANY ADVICE AND INFORMATION
THE SHOER
Old 05-24-2007, 01:55 AM
tbreaden is on a distinguished road
Default Re: nickel plating guns
You can buy plug kits from caswell or I have used Hi Temp silicone let it set up good before plating. It will clean out well when finished.
Old 05-24-2007, 10:15 PM
CarWiz's Avatar
For screw holes, you can plug them or just run a tap in after plating. I've also plugged the holes with the screws I was going to use so they would be plated too. (Leave them above the surface.)
Old 05-25-2007, 12:22 PM
Thanks to both of you
I'll will be ordering some plugs real soon.
Car Wiz
I realy like the idea for screws, it sound like it will kill 2 birds with 1 stone. I've only plated a couple of practice pieces, and dam nervious about plating this gun .
thanks
The Shoer
Improving Plating Performance jimcarry Electroplating Questions 0 09-28-2005 08:50 AM
Gold Plating and Nickel plating tzmandevil Electroplating Questions 2 09-16-2005 09:11 AM
Nickel bath inexplicably quits plating jackf Electroplating Questions 5 01-25-2005 09:55 PM
Differet copper plating questions, plus copy chrome/ nickel? krsimulis Electroplating Questions 1 07-26-2004 12:25 AM
boron plating on electroplated Nickel jackf Electroplating Questions 0 03-29-2004 01:41 AM
