hi I am a wooden box maker from the uk and was wanting to nickel plate some hardware made from brass. I was thinking of using the Electroless Nickel Kit as I heard it is better for getting into all the nooks and crannies for a much more even coat, is this the right method for me?
many thanks boxmaker |
Electroless nickel will work fine for this. You will have to activate the brass with some sort of steel rod. A bolt will work . As long as it's something steel. Just touch the brass with the rod until it starts to activate.
| nickel on brass | baldysm | Electroplating Questions | 2 | 01-18-2007 07:40 AM |
| Gold Plating and Nickel plating | tzmandevil | Electroplating Questions | 2 | 09-16-2005 09:11 AM |
| Problem plating Nickel on to Brass | kuma13 | Electroplating Questions | 6 | 05-17-2005 02:54 PM |
| Brass Plating Tank | agugliel75 | Electroplating Questions | 7 | 02-06-2004 08:50 AM |
| removing nickel plating from brass? | thomaconda | Other Metal Finishing Questions | 2 | 02-27-2003 09:36 AM |
