Old 06-29-2007, 03:26 AM
punkassbob is on a distinguished road
Default Galvanizing and electroless nickel
Hi,
Got a quick question.
Can I use electroless nickel kit on hardware store nuts and bolts?
I think they are galvanized.
Manual mentions zinc contamination is a bad thing.
But aluminum should be zincated first right?
So I'm little confused.
Thanks for your help.
Old 07-01-2007, 07:33 AM
KCV6's Avatar
Moderator
Default Re: Galvanizing and electroless nickel
zincating only leaves a small electroless deposit of zinc. In short yes this will contaminate your solution, but only a very small amount which should not cause any problems. Even thoroughly stripped bolts will still have a small amount of zinc present which ends up in the solution.
Definately strip the hardware before plating.
