i have a 15 gallon trip plate setup with 100 amp rapid technology rectifier i use boster cables for my connections and i use copper grounding rods for buss bars. My problem is when i have been plating for a few hours when i pull my copper anodes out they are coverd in pink junk witch fass in tank. i think its copper but its making a mess out of my tank dont no if thats normal. and by the way i just set it up and new to the plating industry.
You should have your anodes in a bag. I have 18"x18" anodes and I used the bandages from Caswell used fishing line to sew up a bag to fit. You can use rubber bands to hold it at the top.
| Flash Copper Problem | gwjohnso | Plating Pot Metal | 12 | 02-27-2007 11:41 PM |
| Blackening of copper and tin & methods for tin plating | Bulldozer | Other Metal Finishing Questions | 2 | 01-07-2007 03:15 PM |
| Acid copper plating problem! Attention Fibergeek | Gabourie | Electroplating Questions | 10 | 08-14-2004 11:24 PM |
| Strike copper or bright copper after zincate? | mdarr | Electroplating Questions | 2 | 06-29-2003 02:23 PM |
