I'm experimenting with my Copy Cad kit (1 gallon). The power supply that comes with the kit has several voltage settings (1.5 V through 12 V). Which should I be using and why?
I also have a battery charger that can supply 2, 6 or 10 Amps at 6 or 12 volts. I was hoping to use this to plate some larger items. Also, when I was experimenting last night with the kit, I dropped in a piece of black pipe to "purify" the solution as the instructions say (I glass beaded the pipe and degreased it with acetone first). I attached the power supply, and the anode started to bubble as it should. Out of curiosity, I switched the power supply from 1.5 to 3 volts, and the power supply started to smoke slightly. Sorry for all the questions, but can anyone explain some of the voltage requirements? Thanks in advance.
Matt Harwood Harwood Performance Engineering Cleveland, OH Matt's 1941 Buick Century Restoration |
Please post a problem report in our PRS system.
Your adapter will plate items up to 40-50 square inches at 0.75 - 4 volts. See http://www.caswellplating.com/kits/p...ateadapter.htm
| Copy Cad - Success with first time plating | charlton | Electroplating Questions | 3 | 07-31-2005 01:04 PM |
| [b]Epsco 3 AMP Rectifier and Copy Chrome[/b] | gwjohnso | Electroplating Questions | 1 | 03-08-2003 10:11 AM |
| Copy Chrome Immersion system questions. | Great_Scott | Electroplating Questions | 3 | 03-20-2002 05:52 PM |
| Copy Cad Power Supply | MDRSSR | Electroplating Questions | 1 | 01-31-2002 07:39 AM |
