Old 03-21-2003, 01:14 AM
aermakov@rogers.com
Default Couple Copy Cad questions
Hi. I am a proud owner of your Copy Cad kit, very happy with it BTW. Have a few questions.
1. Commercially obtained fasteners are usually zinc plated and then clear chromated. Is there an effective CHEMICAL way to remove the the factory chromate finish in order to replate an then Yellow or Black chromate these nuts and bolts. Re-plating as is produces very dull and rough finish, glass beading solves it, but is very time consuming for a large number of small new parts.
2. Is it safe to use Muriatic acid for rust removal, prior to plating, on parts that have metal and rubber components, brake hoses for example. I am concerned with rubber portion of the part how is it affected. Burst brake hose could be unpleasant.
3. What are the signs of aging Yellow chromate? Lately, I am still getting the color required, but few minutes in hot water (to stop chromating process) wash off almost entire yellow color.
Old 03-22-2003, 12:17 PM
mcaswell's Avatar
Caswell Inc Founder
1. Dipping in an acid pickle will remove the existing zinc plate. See the section in the manual on acid pickles.
2. It depends what the metal is. If it's die cast, then NO. The acid will attack the part.
3. It should last a very long time. Try plating a thicker layer of zinc.
Have A Web Site?
Differet copper plating questions, plus copy chrome/ nickel? krsimulis Electroplating Questions 1 07-26-2004 01:25 AM
Couple of questions... Bobby-S Electroplating Questions 1 06-13-2004 05:34 PM
Copy Chrome Questions junodale Electroplating Questions 13 03-17-2004 12:15 PM
copy chrome/EPA law questions scott63 Electroplating Questions 1 03-11-2003 10:05 PM
Copy Chrome Immersion system questions. Great_Scott Electroplating Questions 3 03-20-2002 06:52 PM
