+ Reply to Thread
Results 1 to 3 of 3
Thread: CopyCad plating on 62 sq. in. object
  1. #1
    Default CopyCad plating on 62 sq. in. object
    I\'m trying to plate motorcycle hubs and sprockets with the CopyCad kit. I\'m getting a rough dull gray plate. I tried a 700ma, 1.5 volt supply with no change in results. I am not sure if I should be increasing voltage or amps to get desired results. Small items such as nuts and bolt plate fine.
    Thanks,
    Dave
    Share with Facebook
  2. #2
    Join Date
    Nov 2001
    Location
    Lyons, NY USA
    Posts
    1,793
    Default Re: CopyCad plating on 62 sq. in. object
    Hi Dave:
    We don\'t take support requests on this board. We\'ve set up an online support system for you to use, which allows us to solve problems more efficiently.
    If you click the \"Need Support?\" link below, you\'ll be taken to our support site, where you can use our PRS system to log your problem. A support tech will post a solution shortly after that.
    Thanks!
    Have A Web Site?
    Share with Facebook
  3. #3
    Join Date
    Nov 2001
    Location
    Lyons, NY USA
    Posts
    1,793
    Copy Cad needs 25 milli amps per sq inch of surface being plated. 62 sq\" needs 1.5 amps, so you are under powered by more than 50%
    Have A Web Site?
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Nickel bath inexplicably quits plating
    By jackf in forum Electroplating Questions
    Last Post: 10-17-2009, 05:39 PM
  2. Gold Plating and Nickel plating
    By tzmandevil in forum Electroplating Questions
    Last Post: 09-16-2005, 09:11 AM
  3. CopyCad & Zinc failure - electrolyte problems?
    By seanc in forum Electroplating Questions
    Last Post: 11-08-2004, 09:16 AM
  4. plating and size power?
    By chromo in forum Electroplating Questions
    Last Post: 01-18-2003, 02:52 AM
  5. Electroless Krome plating Q's
    By chcarver in forum Electroplating Questions
    Last Post: 10-10-2002, 10:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
