I recently contacted a business about doing some plating for me and the guy said that electroless, which is all they do at said company, is a more dull blasted type finish like stainless steel rather than a high polish bright silver.
Is this true? If so, I guess I need to research more because I am after the decorative finish. |
It depends on the type of electroless nickel plating as well as the preplate finish. Generally high phosphorus deposits are duller. The mid phosphorus types can be bright depending on the preplate preparation (polishing vs bead blasting). Electroless Krome can be very shiny if the base metal is polished.
Seth |
Ya, if you blast and plate you get a dull part finish then a dull plate finish, just like the part was dull before the plating.
Buff and polish the part till it shines like a mirror then plate and you get a mirror finish like the part was before plating. Works about the same for most things, paint or whatever, the finished job only looks as good as the part under it. So like painting, if the part is all scratched up, scrapes, dents and dinged, rough, etc... the paint over the junk part will also look as crappy as the part under the paint. |
| Quality of supplies | chrissai | Metal Polishing Questions | 1 | 08-07-2006 12:44 AM |
| quality of Anodiz.... | IAMaxxer | Anodizing Questions | 4 | 05-24-2006 07:23 PM |
| Electroless Krome look and quality? | phunkmastakrez | Electroplating Questions | 1 | 08-10-2005 10:25 PM |
| Removing Electroless finish... | mark123 | Electroplating Questions | 4 | 05-07-2004 08:22 AM |
| Pot Metal Electroless Nickel - Suitability as finish | tgoode | Plating Pot Metal | 6 | 06-17-2003 08:01 PM |
