Old 09-19-2007, 02:02 PM
jaxenro is on a distinguished road
Default Electroless Nickel Plating Firearms
I want to plate two medium/large size revolvers. Would the small electroless nickel kit be large enough for that?
I am trying to replicate the look of an old 1851 navy that was nickel plated but some has work off. Anyone ever do anytign like that? Can I put something on parts to keep it from sticking and peel it off at the wear points?
Old 09-19-2007, 09:17 PM
crob241's Avatar
Caswell Platinum Member
crob241 is on a distinguished road
Default Re: Electroless Nickel Plating Firearms
Sir, I have been using Caswells products and plated several different types from complete rifles to old colt revolvers in gold, nickle and copy chrome. The electroless nickle comes very close to the 19th century used by colt. As for what size kit to use whatever size you buy can be increased by buying more chemicals or a larger tank, when I am plating something small like a handgun frame or similar I use a smaller container like a corning ware 3-4 qt pot and heat it on a hot plate because it gets hotter quicker and for me works fine. Thank you
Old 09-20-2007, 10:04 AM
Thanks - do you think the smaller kit would do two colt revolvers?
Old 09-20-2007, 10:13 PM
crob241's Avatar
You have to now the area your plating, figure out the nickle credits and follow the instructions. Doing that the job will come out fine. I would think the small kit would be fine also ask tech support that is what they are for and have always answered my questions
Old 09-28-2007, 03:58 PM
sross
I do Colt single actions in an enamel roaster pan on a hot plate. As long as the gun is submerged, it's okay. I stand there and stir slowly rather than a pump because I keep checking the temp.
Just getting them clean is the work. BTW--plate it then polish off the wear areas; it'll look more correct.
Also, keep in mind Colt did NOT high polish back then. Nickel was more for rust prevention. They went up to about 600 grit for nickel (320-400 for blueing). 800 wet-or-dry would be more than correct; I use 600.
Colt also polished barrels in a different direction than others did.
Seth
Heater plating out with electroless nickel woodchip Electroplating Questions 0 04-07-2007 11:37 PM
Help !!! - Electroless Nickel Plating nmbapat Electroplating Questions 1 11-16-2006 09:03 PM
electroless nickel plating woody44 Electroplating Questions 1 04-21-2005 10:43 PM
electroless nickel plating woody44 Electroplating Questions 2 04-21-2005 10:31 PM
electroless nickel plating question stevec Electroplating Questions 1 05-29-2002 06:23 PM
