Wondering if this will work. Use 2 CC/CV power supplies to get the current I need. Negative from both power supplies to the work, and the positive leads to the anodes, with anodes jumpered to each other. Set both voltages to max, and adjust the current. Example. Need 100 amps. Adjust 1 power supply to 40 amps, and the other one to 60 amps = 100amps.
Is this the way it would be done? |
| Using 2 power supplies | hurricaneracing | Anodizing Questions | 2 | 09-17-2006 10:30 PM |
| power supplies | mh | Anodizing Questions | 3 | 08-11-2006 02:22 PM |
| Power Supplies | Newton | Electroplating Questions | 6 | 12-15-2004 12:47 AM |
| Cheap power supplies | MrDmB | Electroplating Questions | 2 | 05-03-2004 10:55 PM |
| Appropriate power supplies | potsked | Anodizing Questions | 3 | 12-13-2003 04:21 PM |
