Connect with Facebook
Closed Thread
Old 04-09-2003, 02:31 PM
chcarver
Default Plugging holes prior to plating.
My plan is to plate using the electroless plating system to get an even plate on oddly shaped tubing. However I need to keep the interior of the tubing brass. I was wondering if I could use basic rubber stopper to plug the ends of the tubing when plating. I'm not very good at chemistry and don't know if the plating chemicals will negetively react to rubber plugs/stoppers.
Old 04-09-2003, 05:10 PM
mcaswell's Avatar
Caswell Inc Founder
Sure you can use a rubber stopper. Plastic would be better if you can find a plastic plug, but rubber would work. It might degrade over time from the heat.
Have A Web Site?
Old 05-01-2003, 12:10 PM
chcarver
I found a goos source of high temp plastic stoppers.
http://www.stockcap.com/products.asp
Closed Thread
Nickel bath inexplicably quits plating jackf Electroplating Questions 8 10-17-2009 06:39 PM
Gold Plating and Nickel plating tzmandevil Electroplating Questions 2 09-16-2005 10:11 AM
plugging holes and methods buzzurd Powder Coating Questions 1 12-26-2004 08:48 PM
plugging a hole before plating jim_poter Electroplating Questions 1 02-14-2003 06:06 AM
plating and size power? chromo Electroplating Questions 7 01-18-2003 03:52 AM
