Hi all,
I am learning how to plate nickel and gold color on metal glasses(nickel silver material). I found my workpiece gets bright nickel color in seconds when I set it at 3.5 amp. However, I found the color gets dull or turned dark (looks burned) when I leave it in the beaker over 1 minutes. Could anyone tell me what did I do wrong?? Maybe the copper wire I use is too thin (1 mm dia)?? Thanks in advance Jerry |
You haven't really given us enough detail to go on, but it sounds like you're hitting the glasses with WAY too much power. Low and slow is a better method.
Nickel requires 0.07 amps per square inch of part surface area, for approx 30-60 mins, so unless your glasses are 50 square inches in surface area, you're using too much.
-- Lance Caswell Caswell Inc http://www.caswellplating.com Need Support? Visit our online support section at http://support.caswellplating.com Have A Web Site? Why not join our affiliate program and earn 15% of all sales. Join at http://www.caswellplating.com/affiliate.htm Please support the moderators on our site by leaving reputation for their helpful posts. Read more here. |
| Cups Plates and glasses? | chromo | Powder Coating Questions | 7 | 08-06-2007 01:46 PM |
| need eye glasses plated mat nickel if poss | kennyrayandersen | Services Offered/Wanted | 2 | 10-31-2006 04:32 PM |
| Pot Metal Electroless Nickel kit | 46Dodge | Electroplating Questions | 0 | 08-04-2006 01:35 PM |
| Pot Metal Electroless Nickel kit | 46Dodge | Plating Pot Metal | 0 | 08-02-2006 05:19 PM |
| Metal Polishing Questions for Nickel Plating | pelletman | Metal Polishing Questions | 3 | 07-31-2004 03:09 AM |
