I just did some aluminum door handles today but the Caswell's Zincate solution I used called for 70*. I think the ambient shop temp was about 90. I thought about dropping an ice cube into it but went with it as is. Came out dandy and plated fine with EN.
I used to heat mine, but have since just let it at ambient temp. My shop runs 55-60 F year round, and I haven't had any problems with it. If anything, reaction/zincating may take a few more seconds. My parts are usually warm though, coming from the SP tank and rinse.
In this part of the country, we wear jackets when it gets that cold!!!!
Just finished 10 pieces (starter motor end caps, thermostat housings, oil filter adaptors etc). worked MOSTLY fine. These were severely coroded so I ended out with minor blistering on 2 pieces after much copper building, sanding, building, sanding, buil......... where the pits were quite deep. Not enough prep on my part. I'm going to re-work the pitted areas and try a quick re-zincate and see how it goes. Other than that the zincate worked fine.
Cheers Mark |
| Tags |
| zincate |
| LCD method | SX Paintball | Anodizing Questions | 6 | 04-11-2007 09:52 PM |
| Black Chromate Solution - Particles in solution | MadChemist | Electroplating Questions | 0 | 01-25-2007 02:08 PM |
| Alternate solution heating idea? | dagobert | Electroplating Questions | 6 | 09-02-2004 11:26 AM |
| Zincate | neil | Electroplating Questions | 1 | 07-28-2003 11:04 AM |
| Zincate pre-treatment | plumcrazy | Other Metal Finishing Questions | 1 | 12-13-2001 11:04 PM |
