I want to go from my 3 gal bucket to the next level, open for ideas, Really don,t want the 5 gal. bucket system, Square tanks, anybody making them?? also circulating pumps upgrade, So who is selling what?? 5 gal. area should be enough but the round bucket is holding me up?? Looking for idea,s.Forums area have tank upgrades and ideas from other customers
Thanks v6 i have a new 6 gal. bucket also, heavily into carbs. looking for a easier way, open for ideas.My working area is really small so thats why i asked. i have had a 12 x 12 inch by 12 inch deep tank made for me. Just looking for ideas, its a shame the forums does not handle this type of area.
I see you are heavily into carbs. I did my Holley and ended up zinc plating first then yellow chromate. I didn't like the way it looked when I blasted the housing then into chromate. How do you do yours to make them look original?
Rick |
68 goat, i naturally strip the body and take out idle tubes, screw bolts back into all holes with threads and glassbead the carb. Next after blowing it out, all the little passages, i use my degreaser at 140 degree,s and wash it threw and thru, after i rinse carb. with tap water usually as hot as i can stand it with rubber gloves and air dry carb after blowing it out with air. Next i drop the body into a 5% mauratic acid bathe with distilled water about 1 gal. for id say 40 sec. to a min. and then drop body into distilled water tube and dry it out again the then put carb. into my electrolyte solution for 15 min. to 18 min. 5 volts andi believe 2.3 amps. after its out i drop it into distilled bathe again & then go to the yellow cad solution and swirl the carb. around for 50 sec. to a minute, remove and let air drye. This is what i do!! Only problem im having is that the 3 gal. pale im using now is to small, carb sometimes hits the electroids, not good to do, some little niucks and crannys does not get plated, always looking for better ideas. for sure!!
MrPontiac -- Thanks for the reply. I pretty much do what you do, and just recently started using the muriatic acid dip, which really helped the zinc process. Here is a photo of how mine turned out, I now know that i should have plated (without) brightener, but it is what it is cuz I am not going to do it over. The next one I will try with (no) brightener.
Here is a link to my project, from one Pontiac guy to another............... http://www.wctc.net/~arm/68gto.htm Last edited by 68goat; 01-25-2008 at 04:32 PM. |
Really thought i would of gotten a ton of answers to the upgrade but i was wrong,its a shame that the forums here does not show the set ups everyone is using or better yet newer ideas. Hummmm are you listening caswell
| Anyone looking to upgrade to bigger tanks | bikerrandy | Electroplating Questions | 0 | 05-24-2005 09:55 PM |
| plating only some (unremoveable) parts off a bigger item | nicanor76 | Electroplating Questions | 4 | 05-17-2005 03:10 PM |
