hello guys!
I got an Aluminum item here the process I understand is, Zincate then Flash Copper. Reading the posts here the next step should be to plate in acid copper then nickel? Can I just miss this step out? And brush plate Nickel onto the Flash Copper? The item in question is an aluminum casing and is brand new and shiny. I want to achieve a mirror finish when I will go on to plate in gold. Also what is the difference between Flash Copper and Acid Copper? Thanks for your time |
You can brush plate nickel over the flash copper. The flash copper is alkaline, and can be plated as a strike over steel, pot metal etc. Acid copper can't go over these metals. Acid copper also can be built up very thick, used to electroform.
-- Lance Caswell Caswell Inc http://www.caswellplating.com Need Support? Visit our online support section at http://support.caswellplating.com Have A Web Site? Why not join our affiliate program and earn 15% of all sales. Join at http://www.caswellplating.com/affiliate.htm Please support the moderators on our site by leaving reputation for their helpful posts. Read more here. |
| Nickel Plating Problems After Flash Copper | SLOSteve | Plating Pot Metal | 16 | 08-19-2007 10:20 PM |
| Brush Nickel or Ni Flash | ahammeke | Services Offered/Wanted | 0 | 05-17-2006 02:32 PM |
| nickel copper flash kit | keala | Electroplating Questions | 1 | 08-25-2005 09:30 AM |
| Do you have to use flash copper to plate aluminum | krsimulis | Electroplating Questions | 1 | 07-27-2004 01:32 PM |
| Plug-n-Plating Nickel over Flash Copper | JoeMig | Plating Pot Metal | 0 | 07-22-2004 12:13 PM |
