I am hard chrome plating cold rolled steel the part is 3/14 X 1 3/4 X 3 1/4 I did the water break test. I an using a lamda Rectifier 24 amps 4.75 volts the bath is 110 degrees I checked the specific gravity of the solution and it is 1.162. I went by the book by reversing the current for 10 sec then making the anodes + and the part - at 12 amps for 1 min then ramped up to 24 amps for 3 min then reverse for 10 sec again the 1 3/4 X 3 1/4 suface didn't plate I can ramp up to 6 volts and 40 amps but I get a build up not a Flashed chrome surface. The rectifier is capable of 8 volts 100 amps. What am I doing Wrong?
| hard chrome a gun | inacoma | Electroplating Questions | 0 | 01-14-2007 06:10 PM |
| hard part done | boink117 | Oven Building Forum | 4 | 04-19-2006 07:50 PM |
| Hard Chrome Plating Help | dg5240 | Electroplating Questions | 0 | 05-31-2005 03:17 PM |
| Nickel first before hard chrome? | Daveleeander | Electroplating Questions | 0 | 12-02-2004 11:13 AM |
| hard chrome rectifier | elboriqua | Electroplating Questions | 1 | 11-04-2003 08:44 PM |
