I have just had a go at stripping some chrome parts using a chemical chrome stripper, unfortunately nothing happened. I was using a rectifier that I use for pen plating, its a 1.5amp max, and its voltage is variable between 3 -12 volts. I was wondering if this rectifier is up to the job?
You may also have fallen into a very common trap. Chrome strips VERY quickly because it's a very thin layer, and the nickel plate that's under it looks very similar to the chrome.
Many people call us saying their stripper isn't working, when in fact the chrome has all gone and they're looking at the nickel plate. Test with a stainless wand, connected to reverse plate, and use some stripper solution. If you see a yellow stain on the bandage, there's still chrome on there.
-- Lance Caswell Caswell Inc http://www.caswellplating.com Need Support? Visit our online support section at http://support.caswellplating.com Have A Web Site? Why not join our affiliate program and earn 15% of all sales. Join at http://www.caswellplating.com/affiliate.htm Please support the moderators on our site by leaving reputation for their helpful posts. Read more here. |
I run volts up to 12. or as close as you can. It depends size of part. I would say you may need a bigger rectifier. Sometimes it is very hard to tell if the chrome is removed. You will know when you plate because it will not stick. Todd
| How can I strip chrome from die cast? | DannyD | Electroplating Questions | 1 | 11-26-2006 01:27 AM |
| I need to strip chrome from aluminum? | RedRiver | Electroplating Questions | 14 | 04-23-2006 08:38 PM |
| Best Way to strip Chrome | Live2Ride_88 | Metal Polishing Questions | 9 | 03-16-2004 03:25 PM |
| Can you electro strip chrome with pickle #3? | tbloss001 | Electroplating Questions | 3 | 06-06-2003 09:36 AM |
| To Many Amps | gsuit | Electroplating Questions | 1 | 03-20-2002 05:49 PM |
