Old 02-05-2008, 09:26 PM
JohnDrysdale is on a distinguished road
Default Plating Aluminum question?
Okay I have the Nickel/Copper combo kit and some Zincate. I am trying to plate an aluminum part. After reading the manual it says something on the lines that I need to (flash copper) the part after I zincate it not (acid copper) it. The combo kit comes with the acid copper not the flash copper. Can I go from the zincate right to the acid copper or do I need to buy the other kit?
Old 02-08-2008, 01:04 AM
tbreaden is on a distinguished road
Default Re: Plating Aluminum question?
You can go from zincate to nickel. Make sure you rinse off zincate before you nickel. It can hurt your nickel bath. I like to double zincate (zincate, rinse, sulfuric acid dip for 10 sec.,rinse, zincate, rinse) then flash copper. Then to acid copper if needed. Todd
Aluminum Valve Cover Question ptim Metal Polishing Questions 44 03-23-2007 04:32 PM
Aluminum Plating Question hoytheld Electroplating Questions 4 06-28-2006 01:14 PM
aluminum oxide media question corybarta Powder Coating Questions 5 10-18-2005 11:18 PM
Aluminum question mpierich Metal Polishing Questions 7 08-25-2005 12:07 AM
Question on Chromate/pre treatment for aluminum... Mcurtis7 Powder Coating Questions 0 05-19-2005 05:36 PM
