Old 02-24-2008, 07:07 PM
kingtaco is on a distinguished road
Question Wierd new way to copper plate cheap stainless steel
Howdy all, first time poster, long time lurker. While I'm having my plating room built, I've been doing some "kitchen chemistry" plating copper along with using caswells silver plug&plate.
A mention about the silver plug&plate: Didn't try with the stainless anode, but a .999 fine 1oz bar instead. used as a "brush" it plated ok, but lots of smut and tarnish. as a dip it plated perfectly.
Now back to the copper plating.
I'm used to acid copper plating. My solution is 450ml distilled water and 50ml Hardware store grade muriatic acid (38% iirc) I have a dual voltage current limited laboratory grade power supply, probably built in the 60s. It can supply on each channel 1A upto 20V or 0.5A up to 40v.
I hook one channel of the PSU up to my breadboard where I do my current limiting. I have 8 2.2K 1/2W resistors in parallel for a combined resistance of about 270ohms. I have caps placed both before and after the resistor array to make sure the power stays consistent.
When acid plating, I adjust the voltage to between 4 and 6 volts, to get a current of 0.1A(about appropriate for the size of what I'm plating.) I can plate quarters like a pro with this setup.
Now, I'm attempting to copper plate a cheap "18/0 Stainless Steel" fork. I was able to get copper onto the fork, but it wouldn't stick. I reread the plating manual and it says you can't plate acid copper directly to stainless steel.
Now, since I have a ruined fork, I decided to mess around a little. I made a solution of 500ml of boiling water, and added as much baking soda as would dissolve. I added a copper cathode and hooked the fork up as the anode. Exactly the opposite I would do if I were acid copper plating. In order to get any current through the solution, I have to run my PSU at 20V. That is giving me 0.15A of current. The copper is plating onto the steel!
The solution is also turning a deep blue, with what appears to be some sort of salt accumulating at the bottom. I keep the plating container(a pyrex 2 cup measuring cup) in a pot of boiling water to keep the temperature up. The plate is darker than the acid copper, but seems to adhere well. It also seems to have a smaller "grain" than the acid copper.
I can't explain what's going on here, but it seems I've found a new way to plate copper onto stainless steel.
Discussion is welcome as I'm not sure why what I'm doing is working as well as it seems.
Stainless Steel Look dpbarry Other Metal Finishing Questions 5 11-21-2005 05:27 AM
Copper plate over soder and steel keala Electroplating Questions 3 06-28-2005 07:56 PM
Copper plating on stainless steel 316L strip/sheet slee36 Services Offered/Wanted 0 03-31-2004 12:46 PM
Stainless Steel Help, Please rbkemp25 Metal Polishing Questions 4 06-21-2003 06:59 AM
Stainless Steel old Z1s Metal Polishing Questions 1 05-29-2002 10:21 AM
