Old 03-07-2008, 11:28 PM
caseywan is on a distinguished road
Default Can you put a clear powder coat of Copy Chrome to keep it from tarnishing?
I've been told the only downside to Copy Chrome is that it will eventually tarnish a bit. If you put a clear powder coat over it, would it dull the finish?
Old 03-10-2008, 04:33 AM
KCV6's Avatar
Default Re: Can you put a clear powder coat of Copy Chrome to keep it from tarnishing?
The thing to be carefull with clear coating electroplating is if you use a heat process to cure the laquer or as in your example heat the powdercoat, the plated item will want too out gas hydrogen. I would relief the items first at 400 degrees for a good 2 to 3 hours to force the hydrogen out. If you then polish the item to a high lustre and thoroughly degrease to get the polishing waxes out you should be able to clear coat with a good result.
Disclaimer, I havn't tried clear powder on electroplated stuff before, only clear laquer and only on small decorative pieces.
Clear Powder Coat over Paint???? chcustom Powder Coating Questions 2 12-03-2006 02:08 PM
Shiniest Chrome Powder, and do i need to clear coat it? investinwaffles Powder Coating Questions 5 07-20-2006 07:24 PM
Clear Powder Coat With Flakes CaptainChauncy Caswell Please Sell This... 3 03-12-2005 02:43 PM
Clear coat chrome? merse1 Powder Coating Questions 2 04-13-2004 10:38 PM
using clear powder coat after polish? hybred Metal Polishing Questions 10 04-03-2004 02:42 PM
