Depending on the humidity in your area maybe you could just go with a plastic tarp strecthed out square about 4-6" off the ground weighted alittle in the center to form a funnel type shape. Moisture rising from the ground condenses on the plastic and runs to the center where it drips into a catch container. Also you might be able to catch the morning dew/mist on the top of the plastic and it will run to the center also, just punch a little hole for it to drip through to your container.
Probly not gonna get alot of water, but it works. Also a good survival trick when stranded without fresh water, like in the desert. |
| Distilled Water? | machinist_1 | Anodizing Questions | 2 | 06-08-2005 08:23 PM |
| distilled vs. tap water and anodize time too short | blackcote | Anodizing Questions | 20 | 07-12-2004 06:44 PM |
| Distilled Water vs DI Water | mcgoo49 | Other Metal Finishing Questions | 0 | 03-02-2004 09:20 PM |
| distilled water cleaning tanks | whistule | Anodizing Questions | 0 | 08-04-2003 12:43 PM |
| when do you use distilled water for anodizing? | danimal28 | Anodizing Questions | 3 | 05-15-2003 06:18 PM |
