+ Reply to Thread
Results 1 to 3 of 3
Thread: Shelf Life
  1. Shelf Life
    What is the typical shelf life of the plug n plate kits?
    Share with Facebook
  2. Join Date
    Nov 2001
    Location
    Lyons, NY USA
    Posts
    1,793
    It's unlimited. Sometimes the solution may crystallize slightly. Simply heat it up slightly and stir the crystals back in. Heating is best done in the plastic container, in a microwave. Don't heat it in a metal container.
    Have A Web Site?
    Share with Facebook
  3. Join Date
    Jan 2003
    Posts
    325
    A bit different question, sort of the same.
    I forgot to put away some of my solutions. When using the plug n plate kits I pour some solution into an old yogurt cup. Often I just put the lid on the cup if I will be plating later the same day or next day agian.
    Well, I got busy and forgot I did that last time. I have some gold, probably copper and nickle too that pretty much dried out. Yogart cups are good for use, but don't seal well for storage
    Would it hurt to poor in some solution and heat to disolve those crystals back into useable form? I was gonna give it try later when I get time.
    Didn't know if the crystals might be oxidized and damage the new solution or not. Or if redisolving would eliminate any oxidizing that may have occured?
    The gold is what I would be most concerned about.
    chromo
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Dye life and maintenance?
    By luminous in forum Anodizing Questions
    Last Post: 06-22-2005, 08:54 PM
  2. plug + plate
    By DennyDwyer in forum Electroplating Questions
    Last Post: 03-01-2005, 06:58 AM
  3. Dilute Black Oxide Solution
    By Chet in forum Electroplating Questions
    Last Post: 11-26-2004, 09:03 PM
  4. shelf life
    By cooldad in forum Anodizing Questions
    Last Post: 11-10-2003, 05:50 PM
  5. Anodize sealing bath life?
    By desert_roamer in forum Anodizing Questions
    Last Post: 05-06-2002, 05:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
