Hello, can someone offer me some advice - I was using the Copy Cadinum and Zinc kit on some steel brackets, they were all glass beaded, lightly polished, cleaned, and the first few plated pretty nice, bright shiny plating,,,, then the last piece (prepared the same) simply turned grey along with the anode? what an I doing wrong? the current and voltage settings on my power supply were the same, pieces are the same size, do I need to clean the anode? do the anode get used up this fast? when do I know when they are no longer good? Please advise...
hoopie, may try this for starters, it sorta happened to me also,make sure your copper 1/2 tube is clean and shinny and is your brackets hitting the anodes??
Also make sure you electroplate is around 95 to 100 degree,s. Should be ok i think. P.s./ funny, but the way my circulation pump is postioned sometimes makes a huge differance also. |
| Copy CAd/Zinc Parts plated grey??? | amobine | Electroplating Questions | 11 | 12-27-2007 11:01 AM |
| Bright Copper plating tank anode problem | thiberts | Electroplating Questions | 1 | 07-25-2007 04:28 AM |
| Can you use zinc wire for anode in Zinc Plating (copy cad)? | ms042180 | Electroplating Questions | 2 | 12-23-2006 02:46 PM |
| Anode size for 20" wheel? / cleaning anode | hefrod | Electroplating Questions | 1 | 09-08-2005 04:28 PM |
| Plating Problem grey finish from chrome plating | tshirah | Electroplating Questions | 2 | 08-13-2005 12:08 AM |
