Old 04-20-2008, 10:49 PM
KCV6's Avatar
Default do the caswell re-charge kits contain wetters
Just a general one for the Caswell folk.. Do your nickel/copy chrome re-charge brighteners contain wetting agents as part of the mix? do you sell wetting agents seperately?
Cheers
Mark
Old 04-21-2008, 07:41 PM
Default Re: do the caswell re-charge kits contain wetters
Just about any base or acid will act as a wetting agent as long as it's soluble in the solution and matches the ph. I use H2SO4 as a wetting agent/pre-treat for plating brass and copper but the Pickle#4 sold by Caswell's might be a better choice. But, I'll defer your question to Caswell.
Old 04-21-2008, 09:56 PM
KCV6's Avatar
Thanks CarWiz. I run a Nickelmax setup (pretty much an industry standard mix here in Aus) along with the caswell copy chrome and note that maintenance on theis setup involves addition of wetter as well as brightener. I still have re-charges of copy chrome brightener and just wondering if I should be adding additional wetter?
Cheers
Mark
Old 04-27-2008, 04:33 AM
KCV6's Avatar
Add wetter... makes a huuuuuuuuuge difference. get a sample of any nickel solution in a small container and shake... if it gets a head of froth that disipates real quick you should add wetting agent. The plate comes out much smoother, like chalk and cheese. wetting agent also helps eliminate hydrogen bubbles forming on horizontal edges.
Still curious to know if the Caswell baths contain wetting agents or not? Someone do the shake test perhaps?
Old 05-02-2008, 08:55 PM
amerdunbar's Avatar
amerdunbar is on a distinguished road
I'm not sure what a wetting agent is? I have copy chrome that foams with aeration on, and seems to foam worse when the pH starts to get high.
I've added small amounts of brightener, which usually seems to speed up the need to add muriatic acid to lower the pH... which in turn requires a little hydrogen peroxide to eliminate the rough plate.
Old 05-06-2008, 01:17 PM
cbrooks's Avatar
Caswell Inc Staff
cbrooks is a glorious beacon of lightcbrooks is a glorious beacon of lightcbrooks is a glorious beacon of lightcbrooks is a glorious beacon of lightcbrooks is a glorious beacon of lightcbrooks is a glorious beacon of light
The brightener does contain a wetting agent in the formula.
Craige Brooks
Have A Web Site?
Old 05-06-2008, 09:10 PM
KCV6's Avatar
Cheers Craig.
Mark
How much should I charge? FiReBReTHa Powder Coating Questions 3 05-24-2007 08:09 PM
what would someone charge for ? boucher Powder Coating Questions 2 03-25-2005 10:52 AM
Filter Kits..... minord Electroplating Questions 0 10-30-2003 12:59 PM
What to charge? txturbo Electroplating Questions 9 04-30-2003 09:43 AM
plug-n plate kits or electroless kits Josh I Electroplating Questions 1 10-24-2002 12:48 AM
