Old 04-25-2008, 10:36 PM
hannemcnc is on a distinguished road
Default Flash copper V acid copper
Could anyone tell me the difference between the two.
Which one would be used where and under what circumstances?
Is one more robust then the other?
Looking at chrome plating metal and pot metal. Mainly small car components, grills, small bumper sections that sort of thing.
Also nickel plating many small bolts, nuts and smallish cars parts
Cheers
Old 04-26-2008, 03:33 AM
KCV6's Avatar
Default Re: Flash copper V acid copper
My advice is to get both.
Flash copper is great but slow to build. It will plate over pretty much anything as it is alkaline. Ideal as a substitute for strike coat. If you are doing pot metal (zinc castings)... get flash copper.
Acid copper will not plate over steel and is too acidic for pot metal. It will destroy pot metal.
What I do. Flash copper on all items requiring copper building or nickel plating. If the underlying material was say steel/brass or already nickel and in good condition (no pits or deep scratches) I leave it in the flash copper for an hour, then wet sand fine grit then another hour of flash copper then polish then finish with top plating coat.
If the item is in poor condition requiring thick copper build up I go to acid copper to build.
Hope this helps
Cheers
Mark
Old 04-26-2008, 09:16 AM
Ok Mark,
Thanks for that info, thats the sort of stuff I need to know.
Will get the Caswell plating book over the weekend as the Aus rep lives a few streets over from me. Small world huh.
Cheers Michael
Old 04-26-2008, 11:41 AM
KCV6's Avatar
Sure is Michael,
The Caswell chrome is hard to get here in Aus due to hazardous freight. Makes it expensive. I'd personally leave the larger chrome bits to a restoration shop, there are heaps around, but definately do the copper/nickel/zinc smaller stuff. I do a lot of restoration on car parts. Everything from brackets and nuts and bolts to pot metal badges and door handles. Chrome plating at a restorers is not that expensive if the part given to them is straight and clean.
Feel free to contact me for any other info.
Acid copper not bond on flash copper help mgcobra Electroplating Questions 4 10-10-2007 08:51 AM
flash copper fullthrottle24 Electroplating Questions 2 11-21-2006 12:27 PM
new flash&acid copper plating job/burn through jjones9620 Electroplating Questions 2 03-28-2004 09:31 PM
Flash copper vs acid copper for PCB Holes cdaw Electroplating Questions 3 02-28-2004 09:47 PM
Strike Copper or Acid Copper over Nickel? mdarr Electroplating Questions 2 07-13-2003 01:53 AM
