I'm very new to these concepts. I read on this site that one could plate copper on non-electrically-conducting materials, but there are no comments on this process in the descriptions of the do it yourself copper plating kits. I'm also puzzled how an electroplating technique involving electric currents could be used to plate metal on a non conductor. Is there an electroless process that deposits copper? Can electroless Nickel be used to plate on non conductors? Do these metal films stick to glass? Sorry for the many questions, but thanks for the answers.
Best regards, Tom |
tom,
firstly you have to obtain a conductive layer. ı will give an example on plating plastics. for exaple; when plating plastics (ABS plastic) firstly you must etch the plastic to obtain cavities. then dip the plastic in a special palladium solution. paladium will adhare the cavities surface. the next step is electroless plating. ıt can be electroless nickel or copper but generally we use nickel. and now our plastic parts are conductive. we can plate what we want. general process princible is this. |
Thanks Mark and Platechem for your responses.
One of the things I'd like to do is make a back surface mirror, with the reflecting surface being Copper, on a glass substrate. I'd like the spectrum of the reflected light to be the same as that from Copper. I understand that I will need to first coat the glass with a conductor, which will probably not be Copper. Problem is that If this conductor layer is thick enough to reflect light, it might change the spectrum of the reflected light from that of Copper. Are there transparent conductive coatings I can use as the first conducting layer? Thanks again for your responses. Tom |
| polishing glass | rlandersn | Metal Polishing Questions | 3 | 03-31-2008 01:49 PM |
| Need Electroplating Onto Glass | michaelvall | Services Offered/Wanted | 0 | 12-18-2007 02:22 PM |
| Illusion on Glass? Any one tried it? | chromo | Powder Coating Questions | 2 | 09-16-2007 11:46 PM |
| glass blasting | berndog | Metal Polishing Questions | 2 | 08-24-2005 09:33 AM |
| copper plate zinc came for stained glass? | gronos | Electroplating Questions | 1 | 12-14-2003 07:16 PM |
