Hello all, I'm new here but getting excited to try my hand at electroless nickel plating on my handguns.
My newest project would be to refinish a Sig Sauer handgun in EN so I have a question regarding the aluminum alloy frames on these handguns... According to threads I've read and also the Caswell website, zincate is necessary on aluminum prior to EN, but I've also read that Zinc can contaminate an EN bath and turn out bad results. So what do I need to do to prep the aluminum frame for EN plating? Also, I will need to remove the bluing on the slide prior to plating and I have thought about bead blasting but may take an easier/cheaper way out by using Naval Jelly... Would this harm the base metal? Has anyone used this to remove bluing on firearms? Thanks everyone. |
Got it CarWiz, thanks much. That's pretty much what Caswell said also through Tech Support. I'll just have to remove the existing anodizing first with the anodizing stripper.
Do you have experience using the anodizing stripper? I purchased it once from Caswell and used it for my AR upper and lower receivers but the package did not come with directions on how long to leave in the solution so I think I overdid it... End result was that the receiver got "eaten" away and was noticeably smaller at the end to the point where they would not mate correctly and had a lot of slop after. Any help would be great. Thanks! |
I haven't tried the stripper. The handles I did were cast aluminum and I don't believe they were anodized. If they were, it got stripped when I SC sanded and polished them before processing.
As CarWiz stated, only a few seconds and imediate clean water rinse on the stripper as it does eat away at the aluminium rapidly.
Just a word of advice on the zincate and EN process. Get some aluminium sheet or rod and do a few small test pieces first until you are happy with the result. It is very easy to get carried away in the whole plating bit and make compounding mistakes that ultimately end in ruining expensive pieces of work and a lot of frustration. Cheers Mark |
| more electroless nickel questions | powderhombre | Electroplating Questions | 2 | 04-06-2008 08:26 AM |
| Pot Metal Electroless Nickel kit | 46Dodge | Electroplating Questions | 0 | 08-04-2006 12:35 PM |
| electroless nickel over plastic | jtagger19 | Electroplating Questions | 2 | 04-14-2004 09:22 PM |
| electroless nickel vs regular nickel | Rocky | Electroplating Questions | 1 | 07-24-2003 02:12 PM |
| Electroless Nickel over Chrome | gglines | Electroplating Questions | 1 | 05-12-2002 11:09 PM |
