+ Reply to Thread
Results 1 to 4 of 4
Thread: ็How to plate copper on Hastelloy?
  1. ็How to plate copper on Hastelloy?
    Hi,
    I'm a student working with an electron accelerator and has very limit knowledge about electroplating. One of my accelerator's part is bad and I have to fix it. It is a small Hastelloy C-276 piece (~10 sq.cm) that must be plated with copper on one side to increase conductivity. However, no matter how the plated copper and striked-nickle always peel off. So, I would like to ask if someone has experience in plating Hastelloy C-276.
    The plating I've done is the following :
    First put Hastelloy in HCl 36% for a few minutes then rinse in distrilled water. Next, stike it in nickel chloride bath at 55 degree C for 2-4 minutes then rinse in distrilled water. Then plate it in acid copper bath at 28 degree C for 15-20 minute at low current density.
    I know from my friend that my nickel anode is a low grade one.
    Moreover, I'm interesting in Plug N' Plate kit to fix some specific spot on my machine. My question is that is the plated copper can survive a few megawatt microwave?
    Thanks in advance.
    ZartPARZ.
    Share with Facebook
  2. Re: How to plate copper on Hastelloy?
    For the information about Hastelloy C-276 you can find it at
    Haynes International, Inc.
    Briefly, it is a nickel alloy contain Cr and Mo.
    Share with Facebook
  3. Join Date
    Jan 2001
    Location
    Lyons NY USA
    Posts
    471
    Re: ็How to plate copper on Hastelloy?
    Quote Originally Posted by ZartPARZ View Post
    Hi,
    Thanks in advance.
    ZartPARZ.
    I'm sure no-one here has any experience plating onto those alloys - but I would try to reverse plate the part for a few seconds in the HCL solution to etch the chrome before applying the nickel chloride strike.
    Lance Caswell
    Have A Web Site?
    Share with Facebook
  4. Join Date
    Nov 2008
    Location
    Tucson,Az
    Posts
    114
    Hello ZartPARZ,
    First, H A S T E L L O Y C-276 alloy is a n i c k e l-m o l y b d e n u m-
    c h ro m i u m w rought alloy that is generally c o n s i d e red a versatile
    corro s i o n-resistant alloy.
    Interesting another Hastelloy question. It appears you are your attempts are good but I need more information.
    1. Are you seeing any corrision under the peel plating?
    2. Is your base material seperating clean from plating?
    3. Is base material adhere to the plating?
    To trouble-shoot your problem, need more detail information.
    Process:
    1. Degrease hot 180-200F.
    2. Rinse
    3. Electroclean-reverse current (anodic)
    4. Rinse
    5. Acid dip 36 % HCl-ok but careful it does not attack the alloyed
    (creating pitting-corroision)
    6. Rinse
    7. Woods Nickel strike
    8. Rinse 2x
    9. Copper strike
    10. Copper buildup.
    Do not understand your statement "nickel anode". You are plating nickel after copper?
    Your question "survive a few megawatt microwave"?
    We can deal with that later.
    Write back,
    Nol4154
    armando4154@hotmail.com
    Thanks in advance.
    ZartPARZ.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Do you have to use flash copper to plate aluminum
    By krsimulis in forum Electroplating Questions
    Last Post: 03-31-2009, 05:02 AM
  2. copper plug and plate
    By pabirdman in forum Electroplating Questions
    Last Post: 01-10-2007, 06:46 PM
  3. Stripping tin plate from copper
    By Steve_Eddy in forum Other Metal Finishing Questions
    Last Post: 10-09-2006, 12:06 PM
  4. Copper plate over soder and steel
    By keala in forum Electroplating Questions
    Last Post: 06-28-2005, 07:56 PM
  5. Should I Copper or Nickel plate?
    By robert-a in forum Electroplating Questions
    Last Post: 06-29-2003, 03:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
