+ Reply to Thread
Results 1 to 4 of 4
Thread: chrome or nickel?
  1. Join Date
    Feb 2002
    Location
    Texas
    Posts
    36
    chrome or nickel?
    If I drop a nickel plated part into the chrome tank, when I remove it how will I be able to tell if its worked or not? The nickel looks like chrome when I finish polishing it. So it looks the same when I take it out of the chrome tank.
    1966 Impala (hers)
    1966 Impala SS 427 (his)
    See them at
    The Watering Hole
    Share with Facebook
  2. Join Date
    Nov 2001
    Location
    Lyons, NY USA
    Posts
    1,793
    Nickel has a slight yellow tint to it, chrome has a slightly blue tint. They do look very similar, but you should be able to tell the difference, especially if you put a nickel part against a chrome part.
    Also, the bubbling that occurs during chrome plating is a signal that the plate is being applied.
    If you absolutely have to be sure, try stripping the chrome off again. If you use a reverse brush plating system, you will see a yellow stain on the wand where the chrome is removed. No yellow stain, no chrome.
    Have A Web Site?
    Share with Facebook
  3. Join Date
    Feb 2003
    Location
    Seymour,Tn.
    Posts
    142
    chrome or nickel
    I can't tell if it's chrome or nickel my self. but if you look at the customer gallery you can see the Yellow on nickel plates. don't know why it shows up like that in pic's. must be the lighting i guess.
    WARCHILD
    Share with Facebook
  4. If you hold the part that has been plated up next to a white shirt or piece of paper, the reflection will be white in the part if it has been properly chrome plated. If it is a different color other than white, it is still only nickel plated.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. durability comparison - nickel vs. chrome
    By funkmunky in forum Electroplating Questions
    Last Post: 01-20-2005, 11:01 PM
  2. Nickel first before hard chrome?
    By Daveleeander in forum Electroplating Questions
    Last Post: 12-02-2004, 12:13 PM
  3. Differet copper plating questions, plus copy chrome/ nickel?
    By krsimulis in forum Electroplating Questions
    Last Post: 07-26-2004, 01:25 AM
  4. Chrome, Nickel or copy chrome?
    By dwthomas in forum Electroplating Questions
    Last Post: 02-15-2003, 02:49 PM
  5. Electroless Nickel over Chrome
    By gglines in forum Electroplating Questions
    Last Post: 05-13-2002, 12:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
