I'm having trouble deciding how to hold some parts I want to nickel plate. Imagine a bronze piece 1 x 1 x 1/2 inches. The pieces ar solid with no holes or any place to secure a wire. These are to be plated for asthetics and need to be as "pretty" as possible.
I was wondering if any of you have experience holding parts like this. Thanks, Archie |
Thanks! It's always interesting to me how a solution can be over-engineered. A friend of mine and I had discussed this problem for some time. We neither one have done any plating before. We kept bouncing ideas off each other trying to devise a way to reposition the pieces. It never dawned on me to just reach down and move them with plastic tongs. Dooh!
On a related note... I've read that if you interupt the plating process, that you can end up with layers of nickel that can delaminate. Question is, if I reach down to reposition a piece and it looses electrical contact for a moment, will that do any damage? -Archie |
If it's left in the solution I don't think it will effect the plate. If you're really worried about it, keep the item in contact with the wire when you roll it over. As the wire and/or item become plated, you might have to adjust your current. Nickel has a higher resistance than copper or brass so the plating amps may rise if you're not using CC.
| GOLD PLATING OF LARGE MOTORCYCLE PARTS NEEDED i.e. RIMS, SWINGARM, OTHER PARTS!! | REVS | Services Offered/Wanted | 1 | 12-28-2007 01:36 PM |
| holding parts? | randygrapes218 | Powder Coating Questions | 2 | 07-03-2004 10:53 PM |
| Anodizing not holding color | slug | Electroplating Questions | 1 | 03-17-2003 06:46 PM |
