Old 02-25-2002, 05:57 PM
elocke
Default newbee/caliper plating
I've sandblasted my caliper halves and want the original gold colored cadmium plating like the professional caliper rebuilders use, instead of paint. The Copy Cad Plating Kit is what I'm considering. Do the cylinder bores typically get plated too. If not, can I mask off areas not to be plated and still use the Cad plating kit. Also, what the resulting plating thickness and consistency? I'm concerned that the halves won't seal properly and pistons won't fit correctly if the coating's too thick (around edges, etc).
Thanks
Ed
Old 03-03-2002, 08:21 PM
mcaswell's Avatar
Caswell Inc Founder
Default Re: newbee/caliper plating
You can mask off any areas you don't want plated. The thickness of the plate is determined by the amount of time in the bath, so you have total control over thickness. A bit of experimentation will lead to the correct time for your parts.
Have A Web Site?
Gold Plating and Nickel plating tzmandevil Electroplating Questions 2 09-16-2005 10:11 AM
Nickel bath inexplicably quits plating jackf Electroplating Questions 5 01-25-2005 10:55 PM
plating and size power? chromo Electroplating Questions 7 01-18-2003 03:52 AM
Electroless Krome plating Q's chcarver Electroplating Questions 1 10-10-2002 11:00 PM
Plating process. Dean Electroplating Questions 1 01-02-2002 01:18 AM
