Hello all,
I am looking to finish a good number of parts in black krome, most of them, if not all, are aluminum.
I am an experenced polished and have polished everything to a mirror like polish, and I am ready to order my kits and get started.
If you look at the picture below, you can see most of what I want to plate. Some of the objects are very large.. about the size of a large shoe boxes... I have not calculated the exact surface area, but a rough estimate is about 530 sq inches (if you include the area on the inside, as well as the outside.) for some of the largest pieces.
I aready know I will need a large tank, that is not an issue..
Here are my general questions:
Which kits will I need to buy? I don't need buckets, and i can buy fish tank heaters at petsmart if nessicary, It also looks like i will need an air pump and some air lines, which also is not a problem.
So all I will need is the solutions and anthodes. Correct?
I know i will need zinc, flash copper, nickle (not sure one that yet) and black krome.
How powerfull of a power supply will i need? I am not sure I can run enough power long enough though a car battery and bulbs to plate objects so large.
Any advise on what kind of power supply i will need?
Alternatively; Given the size of the job.. I am willing to accept that I may be biting off more than I can chew, if that is the case does anyone know of a good chrome shop that offers black krome services?
Here is a few pictures:
