I just purchased an EN Kit, and will be plating small brackets, hardware for an auto restoration project.
My questions are:
1. Since this is electroless, I assume Iwill not need to "hang the parts" in the plating solution. Can I just place the parts in the plastic container or do they need to be suspended for uniform plating?
2. If the parts should be supported, what would you suggest to be the best method, i.e wire, a basket, etc. Can it be plastic, or is metal prefered?
3. If I want to mask certain holes/ cavities, can I use rubber type stoppers to prevent the nickel from plating into these features?
Thanks in advance for your input.
LinkBack URL
About LinkBacks
