Connect with Facebook
Old 10-18-2008, 01:53 PM
upncoming's Avatar
upncoming is an unknown quantity at this point
Send a message via AIM to upncoming Send a message via Yahoo to upncoming
Wink brake calipers
hi i have a friend that ask me about tripple plating his brake calipers on his cycle. i wanted to know if i could just plug them up or would they need to be completly torn down for the plating. i dont know how well the rubber on the pistons will hold up threw the steps.
thanks again for those who can chime in on this for me.
D.I.L.U.S.I.
Drive It Like You Stole It
Old 11-07-2008, 12:39 PM
upncoming's Avatar
Thumbs down Re: brake calipers
so nobody has any tips to doing calipers
D.I.L.U.S.I.
Old 11-08-2008, 05:30 AM
KCV6's Avatar
Moderator
Default Re: brake calipers
Definately strip them down. They are usually fairly easy to strip. After copper plating, use a masking agent on the piston bores, bleeder and banjo bolt threads. to prevent plating build up. Tripple plating builds a fairly thick layer. I zinc plate calipers all the time with no need to mask.
A modeling masking agent like testors masksol works perfectly for masking. I use it all the time. Have a look in your local hobby shop where they sell plastic models and paints.
Stripping is a good idea anyway.... nothing like freshly greased seals to bring brakes back to working as they should Use a proper brake rubber components grease when putting them back together.
Cheers
Mark
Chrome brake calipers? PartTimer Electroplating Questions 7 10-18-2008 02:23 PM
Polished brake calipers Tng21 Metal Polishing Questions 3 12-18-2007 08:53 AM
brake calipers precise Powder Coating Questions 7 04-15-2007 12:28 AM
PC the brake calipers?? upncoming Powder Coating Questions 11 06-24-2004 10:51 AM
Brake Calipers and hubs mcarjeff Other Metal Finishing Questions 1 01-26-2002 09:58 AM
