Old 06-10-2003, 03:54 AM
coyote
Default which kits best for hand guns
I have six hand guns that I like to nickel plating.
What would be the best nickel plating kit (Regular with 12 volts or Electoless) for hand guns?
What would the sq.in/ft surface area be on a 45 auto 1911?
Old 06-11-2003, 12:32 PM
mcaswell's Avatar
Caswell Inc Founder
Both will work well on handguns, but since you have 6, I would recommend the electroplating kit. It's more economical.
Not sure what the area would be without seeing it. One trick is to cover all parts with paper, then lay out the paper in a rectangle and calculate the area of the rectangle.
Have A Web Site?
Old 06-11-2003, 09:19 PM
coyote
Thanks for the info. well give the electroplating kit a try in a week or two.
Old 06-15-2003, 07:48 PM
tgoode
Make sure you take the area of the interior of the magwell & the dustcover and the part of the frame where the sear and disconnector live into account as well as the interiors of the other parts you will be plating like the slide, mainspring housing, etc.
It probably doesn't have to be said but don't plate the barrel unless you figure out how to mask it. Better to just buy a commercially available stainless barrel.
Old 06-21-2003, 09:38 AM
danman
probably not a good idea to nickel - chrome plate your six hand guns as finger prints will be more decectable.
need advice about chroming kits darrell Electroplating Questions 3 08-24-2005 05:57 PM
Are there kits available to suit Australian power supply. Ingenious Powder Coating Questions 6 07-28-2005 12:24 PM
Filter Kits..... minord Electroplating Questions 0 10-30-2003 01:59 PM
plug-n plate kits or electroless kits Josh I Electroplating Questions 1 10-24-2002 01:48 AM
1 gal triple plate kits spectraflamed Electroplating Questions 1 04-07-2002 11:13 PM
