Results 1 to 6 of 6
Thread: Nitric acid, where to get it how to use it??
  1. #1
    MrPontiac is offline Experienced Metal Finisher
    Join Date
    Aug 2006
    Posts
    318
    Default Nitric acid, where to get it how to use it??
    Any ideas where i can get Nitric acid Is it i liquid and how do i mix it??
  2. #2
    CarWiz's Avatar
    CarWiz is offline Metal Finishing Guru
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    906
    Default Re: Nitric acid, where to get it how to use it??
    Where are you and what are you going to use it for?
    I can give you an address but it won't do much good if you're in Kilimanjaro. Look for a local chem supply house and pick it up. If you have to have it shipped, count on paying an extra $20 and up for hazardous fees.
    (AAA) - ALWAYS ADD ACID to water. NEVER add water to acid!
    Concentration will depend on your use.
  3. #3
    Join Date
    Aug 2006
    Posts
    318
    use, etching parts befire plating, again is it a liquid or what?? How is it shipped?? Bottle, quarts gallons or ?? what
  4. #4
    CarWiz's Avatar
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    906
    Depending on the concentration and where you get it, it may be supplied in glass or plastic containers sized anywhere from 500ml to 200L (16.9 ounces to 52.8 gallons). Yes, it is a liquid.
  5. #5
    KCV6's Avatar
    KCV6 is offline Amateur Metal Finisher
    Join Date
    Apr 2007
    Location
    Adelaide, Australia
    Posts
    247
    If Nitric proves too difficult to obtain, just use 10% sulphuric or the correct pickle to activate your pot metal castings. Pickles are a correct mix of acid salts for a particular application. To prolong the life of any pickle or speacialist dip process, always rinse and scrub items that have been bead blasted prior to dipping. If not you are just dumping fine particles of metal and glass bead in the solution.
    I purchased 5L of nitric for $15 Aus from the local chemical supplies agent. It was supplied in a 5L PE container.
    Cheers
    Mark
  6. #6
    upncoming's Avatar
    upncoming is offline Amateur Metal Finisher
    Join Date
    Jun 2004
    Location
    levittown PA
    Posts
    130
    YouTube - MAKING NITRIC ACID
    looks like it would take alot time to get enouph to use this to cover a part
    D.I.L.U.S.I.
    Drive It Like You Stole It
Thread Information
Users Browsing this Thread
  1. Nitric Acid
    By kxkraze in forum Caswell Please Sell This...
    Last Post: 11-07-2007, 09:52 PM
  2. nitric acid
    By shawnkloker in forum Copy Chrome Kit Customers Only
    Last Post: 09-29-2006, 08:04 AM
  3. Is there something I can substitute for Nitric Acid?
    By mammothmc in forum Electroplating Questions
    Last Post: 06-15-2006, 07:21 AM
  4. Nitric Acid
    By Newton in forum Electroplating Questions
    Last Post: 02-27-2005, 01:17 PM
  5. Nitric Acid/Desmut problem....Help
    By Easttex in forum Anodizing Questions
    Last Post: 02-19-2004, 11:59 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
