Old 06-14-2003, 06:38 AM
Nikhil
Default Plating worn trumpet valves
I need to build up the diameter of a set of worn trumpet valves (approx 2-3 thousandths of an inch. The valves appear to be nickle plated. Should I strip the existing plating with nitric acid, build up with copper plating, and finish with nickle, or can I just over-plate with nickle?
Also recommendations on temp/voltage and amperage. I would plate in a 1000ml beaker with titanium anode.
Nikhil
Old 06-14-2003, 05:46 PM
mcaswell's Avatar
Caswell Inc Founder
You'd be better off building with copper plate. It's faster to appy and easier to polish to a high shine. You can plate copper over nickel.
Why not use a copper anode? It will speed up application.
Have A Web Site?
Gold Plating and Nickel plating tzmandevil Electroplating Questions 2 09-16-2005 10:11 AM
Plating a trumpet Kurt Electroplating Questions 2 07-22-2005 01:51 AM
How to mask areas on trumpet valves plater12 Electroplating Questions 1 08-03-2004 11:01 PM
plating and size power? chromo Electroplating Questions 7 01-18-2003 03:52 AM
Plating Chrome over Brass mojobari Electroplating Questions 3 10-29-2002 04:28 PM
