Mdarr:
You will be far ahead if you work your base casting to the point you want it to look like prior to the copper plate.
Its a lot more work to work the copper plate after its on then just to finish out the initial casting.
I cant say about the flash copper strike. I go into my nickel bath after zincate and then into copper to build up.
48BUICK
LinkBack URL
About LinkBacks
