+ Reply to Thread
Results 1 to 3 of 3
Thread: remove or not remove old nickel
  1. #1
    Default remove or not remove old nickel
    Hi,
    PLease excuse my english, I write you from France. I'm interested by the electroless nickel kit to plate parts of an old motorcycle. I have read on a post that it was necessary to remove old chrome on parts but is it necessary to remove old nickel and if yes, is it possible to do that with battery acid ? my parts are essentially brass and steel made.
    Thanks a lot,
    Francis
    Share with Facebook
  2. #2
    Join Date
    Nov 2008
    Location
    Tucson,Az
    Posts
    114
    Thumbs up Re: remove or not remove old nickel
    Hola Francisb44,
    Yes, you need to remove all platings:
    1.Remove chrome plating layer with 30 % hydrochloric acid
    (remember acid into water).
    2.Removal of nickel plating layer, two options.
    a. Purchase Caswell nickel strippers?
    b. Nickel Stripper using reverse current (anodic) and surfuric acid.
    1.The Baume should be ~ 52-55 (acid density).
    2.Anodes recommended lead or carbon.
    3.Connect rectifier to anodes and part to be nickel strip.
    For furher information write back on this process.
    Second I recommend electrolytic nickel than electroless nickel. You need to research the best nickel for your use first.
    Nol4154
    Hi,
    Thanks a lot,
    Francis
    Share with Facebook
  3. #3
    Default Re: remove or not remove old nickel
    Thanks,
    I was interested by electroless way because of the simplicity of use. Why do you think electrolytic way is better ?
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. how to remove chrome
    By chargerman69 in forum Electroplating Questions
    Last Post: 01-10-2009, 12:59 PM
  2. Is There A Better Way To Remove Tarnish From Nickel?
    By HowdeeDoodee in forum Metal Polishing Questions
    Last Post: 01-29-2008, 06:17 AM
  3. HOW TO REMOVE CHROME
    By smokeycity in forum Electroplating Questions
    Last Post: 09-19-2007, 02:01 AM
  4. Golf Clubs - How to remove nickel finish prior to refinishin
    By doctordave in forum Other Metal Finishing Questions
    Last Post: 06-03-2005, 03:21 PM
  5. cannot remove scratches
    By clockman in forum Metal Polishing Questions
    Last Post: 08-01-2004, 08:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
