I've set up my plating tank, but I am not able to plate efficiently.
I bought the 2 gallon kit. I added the Copy Cad Zinc concentrate to hot distilled water, added the remaining 2 gallons of distilled water, stirred, dissolved, and let cool Water is 85-90 degrees (using distilled water) and the aquarium heater. I cut the annonde in 1/2 and place one on each side of bucket after cutting a thin strip to stick out of the water to connected together with gator clips, to the + lead on power back I flattend a 1/2" copper tube to make a bar across the top of the bucket. I drilled some holes in it and bead blasted it for a clean fresh surface. I purchased some 18 gauge pure copper wire to make some hangers for the parts I am experimenting with (large bolts, washers, and small brackets). I scuffed the surface with some sand paper to get a good contact with the negative lead. I added 2 teaspoons of brightener. First I purified the tank with a zinc strip hanging from the bar connected to the negative lead. Next, I hung a few parts from copper wire... nothing. I tried creating a robber in case there was not enough surface area... nothing. I am using agitation with an an aquarium pump. My thoughts. I don't think there is sufficient enough contact from the copper hang bar and the copper hangers to the part. What does work...? I CAN plate, one part at a time. I wrap the copper hanger around the part and using needlenose pliers until the connection is very tight. Then I hang it from the bar, but I have to connect the negative lead from the power pack directly to the hanger an inch or so above the water level. Then I start praying for bubbles. Sometimes I get a good connection and I get plating, other times I do not. Sometimes I have to fiddle with the negative lead until I get bubbles. There has to be a better way of hanging parts and getting good contact. What am I doing wrong? |
Please post a problem report in our support section.
I got it working!
I think the copper I was using as hangers hat some protective coating on it. I used some 1/2" wide copper ribbon and screwed on a copper alligator clip. This worked much better. Plating is going smoothly now. Karl |
when i find some copper wire, wether its from a ballast or the store, it almost always has a protective coating on it. i simply take the length i am going to use and give it a good swipe with the torch and burn off the coating.
| nothing is working | danderson | Electroplating Questions | 5 | 01-27-2005 01:31 PM |
| copy chrome stoped working | jtagger19 | Electroplating Questions | 7 | 01-13-2005 11:32 PM |
