Results 1 to 2 of 2
Thread: Zinc Plate Prep?
  1. #1
    Daytony is offline Newbie
    Join Date
    May 2004
    Location
    NE Iowa
    Posts
    12
    Default Zinc Plate Prep?
    How would I go about preping some parts to be zinc plated? Im doing some motorcycle wheel hubs and various nuts and bolts. I don't want a flat (silver spraypaint) look when finished so what would be the best method to prep these parts to obtain a smooth finish? Just glass bead blast and then use a fine wire wheel to slighty polish the part and then its ready for plating?
    Tony M
  2. #2
    CarWiz's Avatar
    CarWiz is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    906
    Default Re: Zinc Plate Prep?
    That would work but keep in mind that the plating will conform to the surface finish--It doesn't fill scratches or pits. If the item looks wire brushed then the plate will look brushed too. For a smooth, shinny finish, the item needs polished. Also, the item needs cleaned after any handling and before plating. Oils, grease, polish and even a finger print will show up as any contaminates on the surface will not plate.
Thread Information
Users Browsing this Thread
  1. Best Way To Prep & Plate Nuts & Bolts
    By dweymer in forum Electroplating Questions
    Last Post: 03-07-2009, 06:10 AM
  2. problem with zinc plate
    By 69t120 in forum Electroplating Questions
    Last Post: 09-19-2006, 11:48 AM
  3. There any special prep for diamond plate?
    By Deecoat in forum Powder Coating Questions
    Last Post: 09-08-2006, 10:10 PM
  4. zinc plate and cad plate removal
    By fxstcguy98 in forum Electroplating Questions
    Last Post: 03-01-2004, 11:46 PM
  5. Aluminum prep for chrome plate
    By jm in forum Metal Polishing Questions
    Last Post: 02-02-2004, 12:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
