Results 1 to 3 of 3
Thread: which one is more effiecient?
  1. #1
    Gently's Avatar
    Gently is offline Newbie
    Join Date
    Feb 2009
    Location
    Parkersburg, West "By God" Virginia
    Posts
    13
    Default which one is more effiecient?
    Well, I am completely new at this, so bear with me please.
    I have intentions to plate brass on lead bullets, I have recieved my manual and understand the process. I have accepted the fact that to do this I will need more than the kit provides, I undertand this and most everything else. But I have ran into a bit of a delimma so here goes:
    1. I need to plate at least .002 with a max of .004 of brass onto a lead alloy.
    2. it needs to be effiecent and somewhat rapid (meaning at least 200 bullets
    per day)
    3. I am obtaining a 12 VDC 30 amp power source (I know amperage for
    plating is calculated by square inches or feet) In my case more is better
    as I do plan to expand to a larger system as I go along.
    4. I will also need to put SELECTED copper plating onto Aluminum molds (I
    understand the process to do that also)
    With this in mind I really need to know which system is better for the needed plating of this thickness. I intend to also get the combo system for Nickel but the brass is a requirement.
    so which is better (as in quicker)? Flash copper or "acid" copper kits.
    I thank ANYONE for their help!
    Mike.
  2. #2
    Gently's Avatar
    Join Date
    Feb 2009
    Location
    Posts
    13
    Default Re: which one is more effiecient?
    Here is an interesting development, As I read the Manual a little more I discovered the answer to my own question. so I guess I just wasted bandwith here, sorry if it annoyed anyone.
  3. #3
    lcaswell's Avatar
    lcaswell is offline Caswell Inc President
    Join Date
    Jan 2001
    Location
    Lyons NY USA
    Posts
    643
    This article might give you a few more ideas:
    Plating Lead Bullets - Powered By Kayako SupportSuite
    Lance Caswell
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
