You can check with Caswell's tech support but I think their EN is 7% phosphorous. Not only will it stand up to the 400* but the heat will make it harder. How large are the racks. One thing you have to watch with EN is strictly adhering to the "Load" limitation or surface area of the item given the solution volume. (A 10 pint kit is limited to 75 square inches of surface area.) Also, you'll need to refresh the solution during the plating process.
LinkBack URL
About LinkBacks
