Results 1 to 2 of 2
Thread: How best to gold plate titanium and hastelloy substrates?
  1. #1
    klemke09 is offline Platinum Member
    Join Date
    Mar 2009
    Posts
    1
    Default How best to gold plate titanium and hastelloy substrates?
    Hello
    I have a two part question, maybe this forum can help with some of these issues (I am trying to gold plate a suite of different materials that will be in contact with high temperature solutions).
    First, I want to gold plate over a nickel plating on a titanium substrate. The gold plated surface will be in contact with a high temperature solution, over a period of a couple of days to a week max. Can this be done? Is Nickel the best suited material to be sandwiched between Titanium and a gold plated surface?
    Second, I want to gold plate onto a hastelloy C-type alloy (that gold surface will also contact a high temperature solution up to 300degC and max. one week time period). What type of plating(s) is/are best suited to be sandwiched between the hastelloy C substrate and the top gold plated layer so that the gold plated surface is stable and does not "peel off" or become otherwise detached?
    Thanks for any advice in advance
    Kono
  2. #2
    NOL4154's Avatar
    NOL4154 is offline Amateur Metal Finisher
    Join Date
    Nov 2008
    Location
    Tucson,Az
    Posts
    114
    Thumbs up Re: How best to gold plate titanium and hastelloy substrates?
    Hello Kono,
    Interesting project.
    1. First question:
    a. My question is high temperature?
    b. Will the test be thermal cycle?
    b. What type of solution acid & base?
    c. Why titanium substrate.
    2. Second question:
    H A S T E L L O Y C-276 alloy is a n i c k e l-m o l y b d e n u m-
    c h ro m i u m w rought alloy that is generally c o n s i d e red a versatile
    corro s i o n-resistant alloy.
    Again need the questions:
    The conditions I am asking is to characterize the plating types (copper, nickel, gold, etc...) for the exposed environment. Remember you need to consider the x, y, z expansion rates of the plating vs the base materials.
    Get back to me and I will ask a Metalurgist friend on the base material
    Hope to hear from you.
    Nol4154
    armando4154@hotmail.com
Thread Information
Users Browsing this Thread
  1. ็How to plate copper on Hastelloy?
    By ZartPARZ in forum Electroplating Questions
    Last Post: 03-29-2009, 03:45 PM
  2. Gold plate
    By warchild in forum Copy Chrome Kit Customers Only
    Last Post: 01-24-2008, 12:14 PM
  3. Gold on tin plate
    By STAINER88 in forum Electroplating Questions
    Last Post: 07-18-2007, 09:23 PM
  4. Gold over existing gold plate
    By cknob101 in forum Electroplating Questions
    Last Post: 02-23-2007, 09:47 AM
  5. gold plug n plate over nickel plate
    By punisher001 in forum Electroplating Questions
    Last Post: 12-13-2005, 05:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
